How to change IMAQ ROI color while adjusting handles
I have an application where a user must draw a rotated rectangle box around an object.  I'm using an color overlay to highlight the box, but when the user is adjusting the roi handles, the box color becomes gray.  The images i'm working with are gray scale images and it makes it difficult to adjust the rotated rectangle box when they are virtually the same color.  Is there any way to change the color of the roi while it is being adjusted?
Pete
(2,649 Views)
Hi pbartko2,
You can change the color of the ROI while it is in place, but there are no settings to change the color while the ROI is being moved. This will always be the default color of grey. You could post this as a suggestion on our Idea Exchange. Ideas voted up on the Idea Exchange are taken into consideration for previous releases. Unfortunately at the moment there isn't an easy way around this issue.
Emily C
(2,624 Views)
