How can I read digital word in labview?
I'm using DAQ card (6259) and I want to read a digital word in it.
for example I want to be able to read the sequence "011000110" that will be send by an outside user (another different kind of card).
what is the best way to do that?
thank you
Message 1 of 12
(4,401 Views)
If the "word" is transmitted in parallel lines, this is very easy. Just configure your DAQ device to acquire digital data per port (by default 8 lines) and configure the DAQmx Read to return data as U8.
If the word is transmitted serial on a single line, you have to acquire data in a buffered approach. The problem that might occur here: how do you know that the first bit you read is really the first bit of your word?
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(4,396 Views)
Hi Jackedi,
I would also recommend the DAQmx functionality to read the word.
What kind of device are you using to send the word?
Message Edited by Pattos on 10-27-2009 04:47 AM
Pattos
LabVIEW Gretchin
Message 3 of 12
(4,394 Views)
i'm using a dsp to send the word
is it possible to get on the same line the first rise as synchronizer and then get the words?
is there an example for such VI?
Message 4 of 12
(4,368 Views)
Is this the same as your other question?
If so, please stick to ONE thread.
Message 5 of 12
(4,364 Views)
no it is not the same
the other one is about tcp connection
here i'm trying to figure if i'm getting bit sequence from anothere component into my DI/O is it possible to read this seq. as a "word"?
transfer it to a string?
Message 6 of 12
(4,349 Views)
Since you did not tell us how the signal looks like (except that it is digital which infact only describes certain states of the signal) we cannot give you proper guidance on how to work with the data.....
The general approach you are searching for is not connecte to LV or a special DIO device... it has to do on "What is the interface (physically)? What do i want to do with the data?"
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 7 of 12
(4,340 Views)
Hi norbert b
I'm not sure I understand you correctly but:
the physical interface is a TTL output into the DI/O and the freq is not defined yet (can be change according LV demands)
the "word" is stream of bits that define several variables I need to save and compare to other measures.
hope it's OK
thank you
Message 8 of 12
(4,331 Views)
jackedi wrote:
[...]the "word" is stream of bits[...]
So it is serial. This makes it hard to know when the "word" starts....
If you manage to determine a start condition for the "word", it is simple a series of Highs and Lows which has to be analyzed by your software.
You should acquire the data with a buffered method (either finite or continuous which is hardware timed).
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 12
(4,323 Views)
Mensaje editado por Wilmer_S
Message 10 of 12
(4,309 Views)
