How can I programmatically launch LabVIEW's "Compare VIs..." function on two VIs?
The command prompt is just
LVCompare.exe "file1" "file2"
 where file1 and file2 are the full paths of your VIs that you want to compare.
Message 11 of 13
(815 Views)
Yes, thanks, I get that.
But the original poster was looking for ways to do it programmatically (or at least through interface), and it looked like he got his solution through those tools.
So I am just curious.
The problem with my original application of command was because I had VI names with spaces, as well as the folder names, so I just put them simply in root with simple names for the sake of experiment. And here is what I get ScreenShot014.png
where I was comparing "Successor-old.vi" with "Successor-new.vi" using a simple command on the command prompt in the LVCompare folder:
"LVCompare Successor-old.vi Successor-new.vi"
Vaibhav
Message 12 of 13
(804 Views)
The command accepts spaces if the full paths are given within quotes "".
But nevertheless, different error appears.
Vaibhav
Message 13 of 13
(800 Views)
