How can I plot multiple curves using the polar plot?
Hi John,
The color of the text on the scale is set within a sub-VI of Polar Plot.vi.  By default a black color box constant is used, but you can select a different color or change it to a control.  To reach this attribute, trace through the following VIs: Polar Plot » Draw Polar Grids » PG scale.  You can also find the VI at labview\vi.lib\picture\polarplt.llb\PG scale.vi.  Towards the center of PG scale.vi Block Diagram you should see a black color box constant wired to the Bundle function.  Change the constant, save the VI, and the scale color should no longer be black when a plot is displayed.
Jennifer R.
Applications Engineer
Message 11 of 12
(1,015 Views)
Chears, bang on what i needed the both of you,
chears, isn't it always obvious when you told?? 😛
John P.
Message 12 of 12
(1,001 Views)
