Frankly I doubt that you're going to be able to measure time interval with much accuracy. You're periidically polling a static digital input and how often you poll is going to vary. You could try polling as fast as possible and eliminate as many background tasks as you can. If your tolerance for the measurement is plus or minus 100 msce, then maybe you'll get a decent measurement most of the time. If it's plus or minus 5/10 msec, then it will never happen. The pc's clock is just not that accurate and a software timed loop on Windows is not deterministic enough. Get a counter/timer board for something really accurate or use a scope to capture the waveform.
