How can I make a Blinking LED ??
I need to make a Blinking LED (when a Boolean signal is available) in my small project (using the display LED in Labview,  not the real LED ).
 How can I do that?
Is there a available function in the Labview for LED blinking ?
Thanks for your help!!
Jack2
(26,474 Views)
Accepted by jack2
This question has been asked before.  A simple search would have revealed the answer.  Right click on your LED and select Create - Property Node - Blinking.  Wire a True constant to the property node to make the LED blink.
- tbob
Inventor of the WORM Global
(26,469 Views)
Do you mean an LED display on your program, or an actual blinking LED semiconductor? There have been numerous discussions on this forum, a few in the last few weeks, about making an display (indicator in LabVIEW speak) that blinks based on various input. If the question is about a hardware one, what do you want to cause it to blink, what hardware do you plan on using?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(26,468 Views)
thanks a lot !
jack2
(26,448 Views)
we'll never know 😉
(26,419 Views)
den after wiring what v have to do with d existing led???
whether we have to remove dat existing led or we have to connect dat existing led wid blinking led????
plz rply asap
(23,156 Views)
thakurshubh wrote:
plz rply asap
Please start a new thread and explain what you want to do. This thread is 5 years old!
Explain what an "existing led" is (hardware, on front panel, etc.).
Maybe attach your VI.
(23,144 Views)
