04-08-2005 01:30 AM
04-08-2005
05:23 PM
- last edited on
12-01-2025
03:48 PM
by
Content Cleaner
Hi Skegsy,
If the output is a current, you can use the analog input of the DAQ Card to make the measurement:
Measuring Current Using the Analog Input of a DAQ Board?
However, the output of a LVDT is usually an AC waveform, hence signal conditioning is required before acquiring the data into the DAQ Card. The tutorial below will provide more detail on how LVDT can be used with DAQ, and provide links to example programs.
LVDT/RVDT/Resolver Measurements
Lesley
