How can I get the local computer's ID and IP address in Labview?
can you please send the code of IP address of multipath output.
Message 11 of 18
(3,828 Views)
Hi Randa,
what's wrong with this description?
Message 12 of 18
(3,826 Views)
it is show only one IP address.
Message 13 of 18
(3,820 Views)
Hi Randa,
did you do this "right-click and select multiple output" thing?
Can you attach your VI?
Can you attach a screenshot of a command shell listing your multiple IP addresses?
Message 14 of 18
(3,816 Views)
yes I choice multipath output
Message 15 of 18
(3,810 Views)
Hi Randa,
when you want to get an array of strings you should also wire that!
Message 16 of 18
(3,811 Views)
Thank you very much
Message 17 of 18
(3,786 Views)
Hi
I have router has  IP address 192.168.4.100 give IP address to three devices  192.168.4.101,192.168.4.102,192.168.4.103, so how can I use labveiw to detect three IP devices  simultaneously. Thank you
Message 18 of 18
(3,755 Views)
