 lsomers
			lsomers
			05-30-2013 10:44 AM
I have data that sometimes varies over many orders of magnitude, and sometimes varies narrowly. To handle the former gracefully, I chose to use a log scale on the chart for this data. However, when the differences are subtle, the chart does not close in any tighter than 1 order of magnitude.
Is there a way to get the chart to come in closer automatically? I've definitely seen ticks for 3.5*10^N, not just 1*10^N - but now they don't appear, let alone using them as the boundaries of the graph.
I'd rather not have to track the chart data in the program and use property nodes to change the scale programmatically myself!
05-31-2013 11:49 AM
Isomers,
What kind of chart are you using in your program? You can put the WaveformChart Property node in a case structure that can adjust the autosize accordingly (or disable it). You can also Programmatically Control the Size of a Waveform Chart. Let me know what you are specifically looking to do programatically and I can see if we have a property and architecture that can perform this action.
Best,
 altenbach
			altenbach
			05-31-2013 01:09 PM - edited 05-31-2013 01:10 PM
05-31-2013 01:49 PM
I was for that in the chart properties, but it only appeared in the contextual menu. That's odd. Anyway, thanks!
 altenbach
			altenbach
			05-31-2013 03:19 PM
 moderator1983
			moderator1983
			06-03-2013 12:40 AM
Hi Altenbach,
What 'Loose Fit' all about?
Can you help with an example VI, which help explaining this?
 altenbach
			altenbach
			06-03-2013 01:03 AM
moderator1983 wrote:What 'Loose Fit' all about?
Here is the property description. (If loose fit is off, the scale goes from the data minimum to the data maximum.)
 moderator1983
			moderator1983
			06-03-2013 04:13 AM - edited 06-03-2013 04:22 AM
I've seen this, but was not getting a clear picture, how the graph looks with 'Loose Fit' True and how it looks when this property is False...!!
I'm too lazy, so was asking you to make one...!!
Anyways... I made it myself.
 altenbach
			altenbach
			06-03-2013 11:14 AM
Yes, it is usually best to make a small example e.g. with two otherwise identical graphs containing the same data and then see how this setting makes a difference. 😄
