You will know the X positions of cursors. poll the data between these positions.
You can get the index of X positions, get the array subset of Y array from these indices
Well, you say xy graph, so this might be a more complicated problem.
For a waveform graph it's trivial. Simply get the two cursor indices (property: cursor index) and apply them to array subset of the data. Is that all you need?
Here's how the above code would look like. using cursor.index instead of cursor.x elimnates the need to include scaling information.
For an xy graph, there could be multiple segments (e.g. imagine a spiral that passes the desired x range multiple times from both sides). This would neeed significantly more code for a general solution.
altenbach wrote:
Sorry, I made that code during the edit window of posting and run out of time. Of course N should be wired with a 2 to get only the first two cursors.
Personally, I would keep the two cursor indices in a shift regsiter and then update only the relevant one via event terminals.
altenbach wrote:Personally, I would keep the two cursor indices in a shift regsiter and then update only the relevant one via event terminals.
Here's a quick draft how that would look like. (note that we might also want to adjust t0 so the x-values are retained correctly).
