06-22-2020 08:15 AM - edited 06-22-2020 08:16 AM
Hi sorin,
@sorin1 wrote:
For example, if UTC date&time is March 26, 2020 16:50:04 (UTC), the value is 3668086204 seconds
Like this?
06-22-2020 08:21 AM
yes, but I need to get current date/time from PC (UTC, not local) and then converts it into seconds
06-22-2020 08:24 AM - edited 06-22-2020 08:25 AM
Hi sorin,
Get current time from PC and subtract offset to UTC.
You get the offset by comparing the result of the timestamp to time cluster conversion with/without UTC flag or by using the %z formatcode when converting a timestamp to a string…
06-22-2020 08:29 AM
Then just use the Get Date/Time In Seconds and convert to a DBL. The timestamp's data is in UTC. The display will, by default, match the system format.
06-22-2020 08:32 AM
Please GerdW, could you post an example? thanks
06-22-2020 08:47 AM - edited 06-22-2020 08:48 AM
Here's what I was saying. The timestamp control shows the system time zone, but the data is still UTC.
07-08-2020 08:54 AM
07-08-2020 04:31 PM
Keeping your log files with UTC timestamp erases any DST ambiguities and other weirdness, like: what happens in the fall when you have two sets of data between 0100 and 0200, and in the spring when you will have a hole between 0200 and 0300?
07-08-2020 06:42 PM
The last system I did, I just kept the system on UTC (set time zone to UTC). Much easier to manage then. It also helped to synchronize with my UUT since it kept a UTC time. I got really good at subtracting 4 or 5 hours in my head to convert to EDT or EST.
