How can I get XY graph look like that picture
Hi everyone
      They are two picture (one name is "I want "(call picture 1),other is "I have""(call picture 2),) in the attach.  I want get the form of the picture 1.
They are a lot of different.
1 The background color is different. I want get the color as picture (white).
2 The y legend in the picture 1 have different position, but I can do it.
Someone can give me any suggestion?Can  I  using other method ?
i want
Message 1 of 21
(3,899 Views)
Hi edongliang,
why do you create a new duplicate thread for an already solved question?
Hint: have you looked at graph properties (and property nodes) and read the help on annotations? For the colors: use the coloring tool (aka brush)...
Message 2 of 21
(3,897 Views)
Sorry , I can get y  legend as the picture 1
the color can be modified in property nodes,but other i donot know how can i do it
Message 3 of 21
(3,893 Views)
Hi edong,
when you don't know how to change colors using the brush tool you should definitely take the basic courses offered by NI!
Open the tool window, select the brush...
Message 4 of 21
(3,891 Views)
Hi GerdW
  I am a beginner. Modifying the color maybe solved by property nodes.
 however , I donot kown how can i get the same picture as the picture1.
liang
Message 5 of 21
(3,889 Views)
This attached file might help you.
Might be this graph will fulfill your need.
Regards
Prabhakant Patil
Message 6 of 21
(3,874 Views)
Thank your for your apply~
But i want get the same picture as picture1
The positon A and B have some differents.
Message 7 of 21
(3,861 Views)
Hi liang,
you will not get the exact same result as in your "picture1".
- The scales will always use full size of he graph. But you may change their min/max to get the (nearly) same result!
- To show arbitrary text in the graph you can use annotations. They show user-defined text at user-defined positions in the graph...
Message 8 of 21
(3,857 Views)
Hi liang,
so you added some pictures:
- You cannot edit the style of the grid lines in a graph!
- Your scales cannot have different sizes in a graph!
If you really want to have the very same look of those plots I suggest using a picture indicator and to draw your plots on your own...
Message 9 of 21
(3,847 Views)
Thank your !
 1 how do you change their min/max.(can you give me example)
2 see picture 1 ,the data strat piont positon is changed ,so the arbitrary text  using  annotations can not meet it.
Message 10 of 21
(3,843 Views)
