How can I generate a burst signal with NI 5421
(2,623 Views)
You can use FGEN Soft Panel and load a waveform file e.g LVM or HWS(Using NI Analog Waveform Editor). You can build a VI to create a waveform according to your wish and save it as an lvm file, which in turn can be loaded into the FGEN Soft Panel and you can generate the same.
(2,596 Views)
