How can I edit a tdms file
Basically I need a way to delete data from a tdms file or add data (from another tdms file for example).
So far I've created a program to convert it into an excel file. From there I can edit the excel file and add/delete channels or groups. Then the program is supposed to convert the excel file back into a tdms file. I'm having trouble with this part.
Is there an easier way?
Thanks, Patrick
Message 1 of 22
(13,739 Views)
I think this can be accomplished through writing VI with TDMS primitives. To be more specific, first, you can use TDMS "read" primitives ( TDMS Read, TDMS Get Properties and TDMS List Contents ) to read the required channels and groups out, then, use "write" primitives ( TDMS Write, TDMS Set Properties ) to write a new file or replace the original file.
Message 2 of 22
(13,714 Views)
Thanks for the input. I use the tdms read and write primitives frequently.
I'm really looking for a way to graphically and intuitively move the data around or add/delete data. I need other people to be able to use this without too much explanation. Excel's interface accomplishes this. Everyone knows how to add/delete a column or copy and paste data. This is why I've been trying to create a program that converts tdms to xls and then back to tdms after editing. The convert xls to tdms step is a little complicated
Do you have any ideas of how I can create an interface like this in Labview?
Message 3 of 22
(13,694 Views)
Don't know if this will help you, but have you tried to use the TDM Excel Add-In? It usually gets installed by default, but you can install it by re-running the installer, or just downloading it.
Message 4 of 22
(13,684 Views)
I do have that installed. That only converts a tdms to xls. I need to keep all my data in the tdms format so my data collection programs can access and add data. The problem is that sometimes there is bad data from the instrument (oscope, impedance analyzer, etc.) because of a loose wire or some other problem. That bad data is stored in the single tdms file that is used for the entire experiment. I need to the user to be able to easily delete that data and continue the experiment.
Thanks for the help
Message 5 of 22
(13,677 Views)
An easy way to interactively edit/manipulate TDMS files is NI DIAdem....
Message 6 of 22
(13,666 Views)
Aside from using all the VI's available in the TDMS palette you could move to a program like DIAdem
Ben J.
Message 7 of 22
(13,651 Views)
I think you can first read data out from TDMS file and use controls and indicators to implement a UI for users to view and edit data graphically in labview, after that, call TDMS write functions to produce a result file. Of course, this involves a lot of programming work to do in labview.
Message 8 of 22
(13,616 Views)
polloc:
I have a VI that you can use to do this. If you convert your TDMS to excel, this VI will allow you to turn your excel file (saved as a .txt file) back into a TDMS file.
Also, the second VI I am including you can remove data without converting away from TDMS.
Let me know if either works for you.
Message 9 of 22
(13,591 Views)
I still can't use the vi
Can show the example how to use the vi
Message 10 of 22
(13,155 Views)
