取消
显示结果
搜索替代
您的意思是:
How can I display a avi-file while acquiring data from a DAQ-CARD at the same time
While my system is acquiring analog data and controlling a motor, I want to display a avi-film (preferably in full-screen, so that the LabView GUI disapears during this process). Are there any VI's to open external players? May I face some problems to lose samples, due to the calling of external players?
0 项奖励
1 条消息(共 5 条)
3,065 次查看
An example that uses the Windows Media Player can be found here.
0 项奖励
2 条消息(共 5 条)
3,064 次查看
I've already found this example, but it doesn't work with the latest media-player. Anyhow, thank you for your answer!
0 项奖励
3 条消息(共 5 条)
3,064 次查看
If you can't use the previous edition of the player, you might try an ActiveX control if there is one available for playing *.avi files. Also, if the player takes up a lot of CPU power, you may see your data acquisition slow down, but you should not see any samples lost.
I hope this helps!
Liz Fausak
0 项奖励
4 条消息(共 5 条)
3,064 次查看
mhi wrote in message news:<506500000005000000F4280100-1042324653000@exchange.ni.com>...
you can also try out this free vi from my website:
http://www.geocities.com/irene_he/FunStuff.html
Irene
0 项奖励
5 条消息(共 5 条)
3,064 次查看
