How can I determine a RGB value of a pixel or group of pixels inside a picture box?
Can anyone tell me if it is possible to determine the RGB value/values in a picture box?
Message 1 of 8
(5,061 Views)
Color to RGB.vi ! Smiley Happy (existing function)
Message 2 of 8
(5,059 Views)
Thanks for the example.
Now how do I get the pixel value from the image?
Message 3 of 8
(5,049 Views)
I'm not sure to understand what you need but I think you should try "Picture to Pixmap.vi"...(same palette than color to RGB.vi)
Message 4 of 8
(5,046 Views)
Accepted by topic author RFB-LMCO
You can use this.
Bruno
Message 5 of 8
(5,010 Views)
That is exactly what I wanted. Thanks for the help.
Message 6 of 8
(4,996 Views)
Then please mark Bruno's message as the solution rather than your own thank you message.  If you go to the options menu to the upper right of your mesasge first, you'll be able to unmark your message as the solution.
Message 7 of 8
(4,968 Views)
There you go
Message 8 of 8
(4,958 Views)
