How can I determine a RGB value of a pixel or group of pixels inside a picture box?
Can anyone tell me if it is possible to determine the RGB value/values in a picture box?
Message 1 of 8
(6,197 Views)
Color to RGB.vi ! Smiley Happy (existing function)
Message 2 of 8
(6,195 Views)
Thanks for the example.
Now how do I get the pixel value from the image?
Message 3 of 8
(6,185 Views)
I'm not sure to understand what you need but I think you should try "Picture to Pixmap.vi"...(same palette than color to RGB.vi)
Message 4 of 8
(6,182 Views)
That is exactly what I wanted. Thanks for the help.
Message 6 of 8
(6,132 Views)
Then please mark Bruno's message as the solution rather than your own thank you message.  If you go to the options menu to the upper right of your mesasge first, you'll be able to unmark your message as the solution.
Message 7 of 8
(6,104 Views)
There you go
Message 8 of 8
(6,094 Views)
