How can I create more than one program shortcuts in LabView Installer?
I have builded 3 executable files in LabView Application Builder. I want to create an installer (using the same application builder) that can copy the 3 files to the same destiny directory, install the Runtime Engine and create (in the same program group) 3 shortcuts for the executables. Is it possible with LabView Installer?
(2,663 Views)
The Application Builder does not offer this option. It is really intended as a basic installer builder. However, you can use other software packages to enhance your isntaller. There are many third party installer builders that you can use to modify the msi file which the application builder create for you. You might want to check one of those out and use it for your application.
J.R. Allen
(2,663 Views)
