How can I create block diagram
Merhaba, labview'de yeniyim. Ön paneli eklediğim VI'nın blok diyagram bağlantısı nasıl olmalı?Ekran görüntüsü 2022-04-04 150309.png
(2,529 Views)
@aysınlab wrote:
Merhaba, labview'de yeniyim. Ö paneli eklediğim VI'nın blok diyagram bağlantısı nasıl olalı?
Hi, I'm new to labview. What should be the block diagram link of the VI to which I added the front panel?
That depends on what you want your program to do...
If you want to communicate in Turkish, post here: Türkçe Forum - NI Community
(2,518 Views)
CTRL-E when you're on the front panel will bring up the block diagram, if that's what you're asking. If you have other questions please be more specific. Also, it would be a good idea to read through available training material and the LabVIEW User Manual.
(2,514 Views)
My plan is as follows, how to set up the horizontal changeover switch servo, which button is shown when I press it.
(2,496 Views)
What have you done and what problems are you having?
(2,476 Views)
I set the front panel, but I don't know how to connect the desired function in the block diagram.
(2,472 Views)
Hi aysinlab,
Did you notice those training resources offered at the top of the LabVIEW board?
(Then you should know how to "connect the functions" in the block diagram!)
(2,454 Views)
