How can I add another input to a control and simulation subsystem?
I tried adding it manually by dragging the wire to the subsystem, but it does not connect. See attached picture for clarification of the situation.
(2,971 Views)
Accepted by topic author Laura121
Inputs and Outputs of a SubSytem work similarly to a SubVI.
You'll need to open the subsystem, add a control to the Front Panel, and wire that control to the connector pane.
The process for a subVI is pretty well documented here
CLD Certified
(2,928 Views)
