How can I add 1D array at the bottom of another 1D array?
i have tried what Reddy has said... but as i have said, it gave a an error message.. pls see my previous messge.. Could you do me a favor and try it yourself? I might have something wrong... thanks..
Message 11 of 16
(1,799 Views)
hi
enable "concatenate inputs" option in the drop-down list. then only it will be added at the end of the array...otherwise you will get multi-dimension array...you will get that error...........
Message 12 of 16
(1,793 Views)
but  as i have said... i dont want it at the end of the previous array... i want to add another ROW..
Message 13 of 16
(1,792 Views)
HI
Check the following attachment, hope it will solve ur problem...
Message 14 of 16
(1,785 Views)
Sorry lokomokoeh, right now LabVIEW is not installed on my system so i cannot try it
Maybe you are stuck up with some small implementation problem
That build array logic should work fine if u have connected a 2D array indicator at the output of this function.
If not try this,
take 'insert into array' funtion from arrays function palete.
connect a blank 2 D array constant at input ( the array into which you want to insert rows)
now, just drag down the lower part fo the function using resize tool and you can connect all your 1D array rows here.
Now if u connect a 2D array indicator at output, you will get the desired operation
A pictorial representation would have made things simple.
right now, this is the best I can suggest
Message 15 of 16
(1,777 Views)
Hi lokomokoeh,
Yes I did this favour for you and tried it myself Smiley Wink
Follow any of the two methods shown in this attached pic
both will work
Regards
Dev
Message Edited by devchander on 07-21-2006 05:56 AM
Message 16 of 16
(1,768 Views)
