XControl: Arrange properties in submenues
Hello
Is there a way to arrange/collect properties of an XControl in submenues like e.g. the  'Active Cell' properties of a Table?
Or when using a cluster as the datatype (e.g. Width, Height) of a properties it would be nice to get a property with a structure like
All Elements     ->    Cluster
Width                 ->    Numeric
Height                ->    Numeric
and not only a Cluster of 'All Elements'.
Thanks for your help
codas
(3,156 Views)
Hi Codas,
I don´t know any possible settings to arrange Properties like you demand. And I don´t found any Knowledgebase about your Suggestion.
Perhaps you should use the Product Suggestion Center.
http://digital.ni.com/public.nsf/allkb/EDA7C01C684ACB6286256FF0000238D5
A. Rudolph
NI Switzerland
(3,143 Views)
When you create a new property, use ':' in your property name.
For example, name your property as
Active Cell: Weight
Active Cell: Height
(3,139 Views)
This is great! - Works fine!
Thanks a lot.
And how can I place a seperator line?
Kind regards
codas
(3,136 Views)
no idea~~~
(3,132 Views)
