Hi Rainer
Thaks for the Hint, But I figured it out By playing with the application controls and so. But i wonder if there are in the property node, function that can
Close the Sub vi,, with out closing the hole Main VI. With it.
Coz if I press the Openfile button to open the Sub VI, and don't select a file to read from, and press the cancel button of the appeared "open file" window, My main VI stops, how can I avoid that. I want example make an cancel button in the sub VI!!
Is it possible.??
Zamzam
HFZ
