How To Open a subVi by pressing an "open file button",
I got this Readdatasubvi I want to run when I press a 'Open file' button in the main vi, Then  The sub vi runs and a open file menu opens to choose a file to read from and plot out to a graph. It is working but how can I see the readDataSub VI as an application wich are running parallel with the main VI. It only runs in the background, and I cant see the plottet data Why????? The sub vi has a graph for the plotted data! but it never shows up!
an example is attached..
I'll appreciate any suggestions .
The stars are ofcourse waiting!
Zamzam
HFZ
(4,037 Views)
this is because the open/create..vi calls the "file dialog.vi" inside.
The file dialog.vi opens its frontpanel automatically.
If you want your vi to show its frontpanel do the following:
In Labview open your ReadDataSub.vi.
-> file -> vi properties
category: window appearance -> custom -> customize
check "show frontpanel when called"
check "close afterwars if originally closed" if you want to close the frontpanel after execution.
Rainer
(4,033 Views)
Thanks man....
 that was a release...
Zamzam
HFZ
(4,023 Views)
There is still another way to do this from software.
1. place a property node on the blockdiagramm the vi you want to open. (application control-> property node)
2. right click on the property node then
3. select class -> VI Server -> VI
4. change properties to write
5. select "Front panel Window -> open"
with this property you can handle if front panel opens or not.
Rainer
(4,012 Views)
Hi Rainer
Thaks for the Hint,  But I figured it out By playing with the application  controls and so. But i wonder if there are in the property node, function that can
Close the Sub vi,, with out closing the hole Main VI. With it.
Coz if I press the Openfile button to open the Sub VI, and don't select a file to read from, and press the cancel button of the appeared "open file" window, My main VI stops, how can I avoid that. I want example make an cancel button in the sub VI!!
Is it possible.??
Zamzam
HFZ
(3,992 Views)
i tweaked you example.
I guess that's what you're looking for.
Rainer
P.S.: I unchecked the "open frontpanel" in the vi properties. i open (close) the frontpanel using property nodes now.
(3,991 Views)
A lot of thanks to you.
Exactly what i was searching!!
ZamzamSmiley Wink
HFZ
(3,978 Views)
