How To Build a matrix of zeros
I am trying to build a tsunami Simulator and I need to create an empty matrix of zeros for the three variables u,v and b. How do I go about doing this?
The code I need to enter is:
% Build empty u, v, b matrices
u=zeros(length(x), length(y), length(t));
v=zeros(length(x), length(y), length(t));
b=zeros(length(x), length(y));
h=zeros(length(x), length(y), length(t));
Sam
(4,827 Views)
You probably mean array, as matrices are 2D arrays in LV, so that won't apply to your 3D example.
The Initialize Array function in the Array palette will do the job:
In your case, expand it to 3 dimensions:
(4,824 Views)
Thank You Very Much
(4,808 Views)
Remember to mark a post as a Solution if it solved your problem (and give Kudos where appropriate Smiley Wink)
"If anyone needs me, I'll be in the Angry Dome!"
(4,800 Views)
