How I can create complex decoration group with color change option ?
Hi all,
Version: Labview 8.5
I have a followed problem. There is many decorations on my front panel and I have to update front panel quite often. I have to also change most objects color online. My present solution is based on using decoration property. Only problem is that when I add new decoration I have to update code. This is very frustrating because there is hundred decoration objects. I know that one solution is use e.g. boolean control and change its faceplate. Problem is that I need more than two color option. Is there any way to create group of decorations which have a property node or other structure to change color?
(3,677 Views)
H SnowForest,
Could solution to your problem be found on this thread: Can I link a property node to a group of controls
http://forums.ni.com/ni/board/message?board.id=170&message.id=295299
Hope this is helpful,
Veikko
(3,642 Views)
Veikko,
An old joke from my youth was told using an index card.
On the front side it had the text;
How do you keep an idiot busy? (Turn over)
On that back side it contained the same text.
Please check the link you provided.
Ben
(3,626 Views)
Ben,
I just remembered unforgettable words from cult movie Ford Fairlane
"You're 10 seconds away from the most embarrasing moment in your life."..
Forgive me, it  was early morning post..
Now I´m not even sure if this what I meant to send will help SnowForest.
Can I link a property node to a group of controls:
http://forums.ni.com/ni/board/message?board.id=170&message.id=188524&requireLogin=False
Veikko
(3,616 Views)
Accepted by topic author SnowForest
Answer was build  a XControl. Only add decos to XControl facade and simply code to change colors.
(3,259 Views)
