08-03-2020 08:06 PM
I made a VI that reads the temperature and humidity of the graph.
I succeeded in using cursors to read values for each plot.
But what I want is to get two values for one cursor at the same time.
In other words, I want to get two Y values for one X value at the same time.
What should I do?
08-04-2020 12:39 AM - edited 08-04-2020 12:41 AM
Hi seongmo,
What should I do?
Read the x position of one cursor.
Then find the corresponding Y data for each plot based on this cursor x position…
Btw. IndexArray is resizable for more outputs: no need for two IndexArray functions. And it also counts its index inputs automatically starting from zero, so you don't even need those index constants…
