How Can I Change Fix Point Numeric Control's Word and Integer Length
Hi guys.
Can i change Fix Point Word length programmatically at runtime?
(3,455 Views)
You can't.  That is changing the datatype of a wire.
(3,442 Views)
Hımm . I think i can use property node of fixed point numeric control or constant. But on the property node menu, word length does not appear.
(3,438 Views)
You were just told why it doesn't appear in the property node.  Generally if you think you can change a property, you should look at the property node.  If it's not there, you'll want to value the property node's denial over your "thinking."
(3,436 Views)
Ok. Thank you so much.
(3,433 Views)
