03-21-2015 03:41 PM
Hi guys.
Can i change Fix Point Word length programmatically at runtime?
03-21-2015 04:03 PM
You can't. That is changing the datatype of a wire.
03-21-2015 04:15 PM
Hımm . I think i can use property node of fixed point numeric control or constant. But on the property node menu, word length does not appear.
03-21-2015 04:18 PM
You were just told why it doesn't appear in the property node. Generally if you think you can change a property, you should look at the property node. If it's not there, you'll want to value the property node's denial over your "thinking."
03-21-2015 04:23 PM
Ok. Thank you so much.
