04-04-2019 07:31 AM
I have a waveform chart which i'd like to add a reference line for setpoint and deadband. I can't seem to find any property nodes for markers which can easily set reference markers due to requiring a cluster for the waveform data.
How would I go about adding a reference line?
04-04-2019 07:38 AM
04-04-2019 07:42 AM
Hello GerdW,
Thank you for the quick response.
So essentially if i was charting a sine wave(amplitude from 0 to 10) and I wanted a reference point of 7 I would just chart the sine wave but also build a constant plot of 7's ontop of the sine wave? Merge them with a build array into waveform chart?
04-04-2019 07:46 AM - edited 04-04-2019 07:48 AM
Hi Patrick,
Just look at the context help for your chart: it will show you the datatypes expected by your chart…
(You don't "merge" with BuildArray, you just build arrays by prepending/appending.)
