‎03-21-2021 10:10 PM
How to use labview to encrypt a string with HmacSHA1.
‎03-22-2021 02:26 AM
Hi LTYHFA,
You just need to implement your algorithm using all the LabVIEW functions you have available!
‎03-24-2021
04:55 AM
- last edited on
‎04-02-2026
07:49 AM
by
Content Cleaner
There's a SHA1 implementation here (https://forums.ni.com/t5/Community-Documents/SHA-1-Cryptographic-Hash-Function/ta-p/3494144)
You could use that as part of your implementation for Hmac-SHA1 if you wanted?
A description of the process (along with pseudo-text-code) is available on Wikipedia - it looks fairly approachable:
https://en.wikipedia.org/wiki/HMAC
LabVIEW has XOR and comparison functions on the Numeric palette, and so you'd probably just need to be careful with datatypes (I'm guessing the String to Byte Array node might be useful, but I haven't tried).
