High Through Put Example (LabView FPGA FlexRIO Memory)
I am trying to collect data from an ADC that samples at 2MHz, but the High Through Put Example in LabView FPGA FlexRIO runs at 125MHz and complains that I am not responding Quick enough at 63 Clock Cycles between ADC Sample rate.
(1,490 Views)
Hi Edmund,
and what is the question?
Mind to attach your code, with some more detailed information on your problem(s)?
(1,438 Views)
