12-16-2004 11:09 AM
12-16-2004 11:20 AM
12-16-2004 11:22 AM
@ChrisP wrote:
Is there a way to use an array or cluster control without a frame around it appearing on the front panel? I've tried using the paintbrush tool to make it transparent and customizing the control so the frame size and position were different from the content area with no luck.
Thanks in advance
12-16-2004 11:24 AM
12-16-2004 11:35 AM
12-16-2004 11:51 AM
12-16-2004 01:41 PM
09-02-2009 11:10 PM
09-02-2009 11:31 PM
Duplicate Post. And in what version of LabVIEW do you want it?
And why don't you just try the instructions listed above to modify an Array yourself. You might learn more by doing than by having it done for you.![]()
If you don't know how to use the color tools in LabVIEW, perhaps you should take some tutorials.
