Hide Axis legend
I want to hide the legend text on an axis. I'm using a number of custom divisions instead. Setting the Visible property on the Axis to false obviously doesn't work (since it hides the custom divisions as well). It sound pretty trivial, but I can't seem to find it. Any ideas?
greetz.
Piscator
(2,794 Views)
Hi Piscator
You're talking about the axis label, right? Use the property X Scale (or Y Scale) > Name Label > Visible.
Daniel
(2,789 Views)
No. I'm talking about the text of the legend itself: the numbers. I only want the custom divisions to show on the y-axis, not the numbers of the actual values.
I actually meant to post this in the Measurement Studio forum, but LabView looks much alike.
greetz,
Piscator
(2,786 Views)
If you want to do it at design time you can right-click the graph > X/Y Scale > Style.
To do it programmatically the property is X/Y Scale > Style. Just feed it with a number from 0-8 according to the icons you see if you change it manually. I think number 2 or 8 is what you're looking for.
(2,782 Views)
Thanks for your help, dan_u.
The numbers of the Axis appear to be generated by the MajorDivisions property (I wasn't aware of that). So setting the LabelVisible property to false on that worked as a charm. So it was in the direction of your first answer.
greetz,
Bert
(2,775 Views)
