Hi I'm using tca9548a mux with 4 mcp4725 DAC module. I need a solution to do i2c communication.
TCA9548a's address is 0x70.
MCP 4725's address is 0x61.
I want to make a analog signal with mcp4725 dac module. But I don't know which command that I have to use.
I made already analog output with mcp4725, but the problem is mux.
I'm doing a I2C communication by linx but it doesn't work at all
I connected a dac's sda,scl to sd0,sc0 of the mux.
my question is
1. The way to connect pull-up registers.
2. LINX I2C commands.
I posted my vi file and I have less knowledge of programming. Though it looks not that good, please help me.
Thanks.
Message 1 of 1
(2,347 Views)
