Hi, I'm trying to write a code in Labview that will run a scara robot, Its gonna be 2 axis, one linked to a gam
matic motor and the other to a mutshibishi motor, I already have the code for the gammatic motor, I need an other one for the mutshibishi one....guys, I come from a production management engineering backgound and I sack in programming, would anyone help methe idea behind is to see an accuracy between the data entered in term of positon, speed motion of the 2 axis of the scara robot and the data received
(3,108 Views)
matic motor and the other to a mutshibishi motor, I already have the code for the gammatic motor, I need an other one for the mutshibishi one....guys, I come from a production management engineering backgound and I sack in programming, would anyone help meNagui,
Unfortunatley I cannot help you devlop all of your code. Are there any perticular areas that you are having problems with at the moment that I could help you with??
Tristan
(3,106 Views)
Hallo Tristan,
Do you have integrated trajectory planning as functions in motion software? Can you send me any document about them?
Best regards
mark
(2,929 Views)
Hi Mark,
What do you mean by integrated trajectory planning functions?  Could you give an example of what you would use these functions for?  Our SoftMotion toolkit can do path planning and trajectory generation, is that what you are talking about?
Maclean G.
Applications Engineering
(2,903 Views)
