Hi Guys! Does anyone know how I can make my code simple? (See attached code)
My goal is to turn LED ON and OFF automatically every time I change the number in the input field (CONTROL).
I mean I am able to do it with my code. I kind of feel like there has to be a simple way to do this.
Can you please share your code or idea?
P.S: If you think the way I do this is the best and simplest way, let me know too.
Thanks!
See attached VI.
P.S: Event structure is excluded.
(1,850 Views)
As always, your code is just plain silly!
  • Having a hidden array control to serve as an empty array is pointless
  • inserting a scalar into a empty array, then indexing out that element just returns the original value? Why all that extra code?
  • Your local variables are read way before the terminals are written, they will most likely always be equal. Race condition!
  • How are you planning to ever stop the loop?
(1,830 Views)
What does that even mean?
  • Change the LED to the opposite whenever the value changes?
  • Change the LED to TRUE for a limited amount of time for every change in the control? For how long?
(1,826 Views)
Accepted by topic author GRCK5000
If you look in the comparison palette, there is this function. You could use it.
(NOTE: It will also trigger on first call).
Alternatively, you could make your own, e.g. as follows:
(NOTE: This will not trigger on first call)
(1,822 Views)
Thanks Mr. Altenbach for the feedback. This will help me work hard on improving my code and understanding better what I am doing.
(1,732 Views)
This is so simple. I think so hard for no reason. smh
(1,725 Views)
