Hexadecimal Big String to Decimal Numbers
Sorry Sir, i have attached the wrong VI file here's the correct one
Message 21 of 30
(1,505 Views)
Sorry posting by phone, cannot look at your code.
Both functions have their inverse, so that should be trivial to do. What is your starting point?
Starting  with the comma delimiter string, use string to byte array, then array to spreadsheet string with %02x as format and space as delimiter.
Message 22 of 30
(1,496 Views)
NO sir i am giving continuous number input and real time conversion of that number to hex format or ASCII format
Message 23 of 30
(1,488 Views)
I don't know what you mean by OR. You also don't define highly ambiguous words such as "continuous", "real time", "hex format" and "ASCII format".
Message 24 of 30
(1,486 Views)
This is what i am trying to do sir
Message 25 of 30
(1,483 Views)
Try to understand my code and you'll immediately notice that your code makes no sense. Hex format is only defined for integers. Also, casting gives you a generic string. ASCII defines mapping of bytes to characters, irrelevant here. What defines your loop rate?
Message 26 of 30
(1,469 Views)
Here Loop rate is not defined sir it keeps on running untill i press stop i did this because i want to change the values while code is running
Message 27 of 30
(1,463 Views)
What Altenbach is saying is that you have a CPU burner of a loop there.  It will run as fast as the CPU allows it.
Put a small wait statement in there and you won't hear the fan in your PC spin up super high trying to keep your CPU cool.
Message 28 of 30
(1,461 Views)
Here is one possibility. You probably need to adjust the first format (current %f) to something that gives you the right number of significant digits. I don't know the specs.
Still, that entire communication seems very convoluted. What were these guys thinking!
Message 29 of 30
(1,446 Views)
Sorry Sir, i didn't mean to make the conversation complicated but still you helped i really appreciated that thankyou Smiley Embarassed
Message 30 of 30
(1,436 Views)
