Hex to Normal display
Hello
I have a problem with hex to normal conversion:
I have the constant string that is a date 03/02/2010 12:30:00 ( Normal display), if I use the Hex display it will be 3033 2F30 322F 3230 3130 2031 323A 3330 3A30 30
So I if  I write this Hex display of the date into a another string diplayed as normal, how can i convert this value to the initial date?
Message 1 of 21
(6,196 Views)
Hexadecimal String to Number vi should help.
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
Message 2 of 21
(6,192 Views)
Why do you want to this back conversion? Why don't you connect both of the strings using wires? Post what you have did so far. We will help you out.
Mathan
Message 3 of 21
(6,188 Views)
enzo78 wrote:
Hello
The point is that converting the value in another format and displaying it in another format is not the same. You are displaying the value in HEX, but it is not in HEX as I understand. So you do not need to convert it, just set that another string indicator to display in normal format.
And if you have a string in HEX, then you can use the vi I have mentioned above.
Message 4 of 21
(6,177 Views)
Hi All
I have attached the example
Message 5 of 21
(6,167 Views)
This is the beginning I have made.
There are two  drawbakcs:
1. No spaces in the input HEX code available.
2. The result is given with a space between every character.
This is how it looks like:
Maybe this will give you some ideas while moving on.
Message Edited by Giedrius.S on 02-04-2010 04:53 PM
Message Edited by Giedrius.S on 02-04-2010 05:00 PM
Message 6 of 21
(6,139 Views)
Accepted by enzo78
Did the snippet creation create the for-loop with a constant of 1?
Now for the trivial solution:
  1. Right-click on the  Prompt User for Input Express VI and select "Open Front Panel".
  2. At the dialog click on the "Convert" button.
  3. In the new VI that gets created right-click on the "Key" string control and select "Hex Display".
See attached.
Message 7 of 21
(6,121 Views)
My solution with no drawbakcs.
Anyway, it is very possible that there was a more efficient way to solve this. While I am only a novice, this is the best what I have managed to come with 🙂
smercurio_fc,
No, I have made those changes to simplify the execution for testing the program. Originally, while loop was given.
Message Edited by Giedrius.S on 02-04-2010 05:42 PM
Message 8 of 21
(6,116 Views)
Thanks for the help to all
Message 9 of 21
(6,086 Views)
Hy all.
I'm new on this forum, and I'm coming from Slovenia, so sory in advance for ma "bad language".
I'm kind of "a fresh starter" in LabView, so I turned to you guys, if U could help me with this problem, that I have.
So...
I'm building VI, to whom i get Hex string from byte array. Now i have to convert this HEX string into a DBL number.
I tryed like this:
- convert byte array to string
- then HEX string into a number
But I always get "0" out.
For example, if I put in the HEX string "1388", I would have to get the number 5000 out. But i get "0" all the time.
Thanks in advance...
Message 10 of 21
(5,991 Views)
