Henon map
hello all,
I am trying to create a Henon map illustration on labview but i have some errors. the vi is attached. i hope someone helps
Message 1 of 9
(4,606 Views)
Your data is 2D, so why are you trying to use a 3D graph? Try an xy graph instead.
Message 2 of 9
(4,602 Views)
i want to use the comet drawing. and the XY is not working
Message 3 of 9
(4,600 Views)
Then create an array of equal lenght with all zeroes and wire it to the z input.
Define "not working" (broke wiren, wrong display, computer bursts into flames, etc.) . Seems to work just fine here.
Using mathscript instead of matlab.
Message 4 of 9
(4,595 Views)
it is working now after adding the zeros for z, but can i slow it downn ?
Message 5 of 9
(4,586 Views)
oh thats great !!
Thanks Man !
Message 6 of 9
(4,583 Views)
typically people want code to go faster. 😄
The way you are graphing it, is all points at once!
If you want to animate the graph, showing more and more points, place the graph inside a FOR loop with a small wait and use longer and longer subsets for each of the three arrays.
Message 7 of 9
(4,576 Views)
i am getting this graph how to change it to look like yours ?
Message 8 of 9
(4,568 Views)
Accepted by topic author mah11
Change the plot style to points (click on the legend in the upper right corner and change the point style and interpolation).
Of course a "real" LabVIEW programmer would do it as follows. Much simpler! 😄 (note that I initialze with 1,0 to eliminate the points at 0,0 and 1,0)
Also see the attached VI (LabVIEW 2013).
Message 9 of 9
(4,549 Views)
