Henon map
hello all,
I am trying to create a Henon map illustration on labview but i have some errors. the vi is attached. i hope someone helps
Message 1 of 9
(4,545 Views)
Your data is 2D, so why are you trying to use a 3D graph? Try an xy graph instead.
Message 2 of 9
(4,541 Views)
i want to use the comet drawing. and the XY is not working
Message 3 of 9
(4,539 Views)
Then create an array of equal lenght with all zeroes and wire it to the z input.
Define "not working" (broke wiren, wrong display, computer bursts into flames, etc.) . Seems to work just fine here.
Using mathscript instead of matlab.
Message 4 of 9
(4,534 Views)
it is working now after adding the zeros for z, but can i slow it downn ?
Message 5 of 9
(4,525 Views)
oh thats great !!
Thanks Man !
Message 6 of 9
(4,522 Views)
typically people want code to go faster. 😄
The way you are graphing it, is all points at once!
If you want to animate the graph, showing more and more points, place the graph inside a FOR loop with a small wait and use longer and longer subsets for each of the three arrays.
Message 7 of 9
(4,515 Views)
i am getting this graph how to change it to look like yours ?
Message 8 of 9
(4,507 Views)
Accepted by mah11
Change the plot style to points (click on the legend in the upper right corner and change the point style and interpolation).
Of course a "real" LabVIEW programmer would do it as follows. Much simpler! 😄 (note that I initialze with 1,0 to eliminate the points at 0,0 and 1,0)
Also see the attached VI (LabVIEW 2013).
Message 9 of 9
(4,488 Views)
