Help with sequential testing
I am trying to create a test that uses Labview to interface with an arduino that turns on and off relays. The example code I have included is what i want it to do, but it uses a lot of local variables. I was wondering if someone has a better idea on what to do. If possible I would like to be able to reset all of the indicators and controls back to default state at the beginning of a test (I wasn't able to figure out how to do that).
(I am just using constants to prove my point so I didn't put the Arduino (LINX) sub vi's in the code)
Thanks.
Message 1 of 8
(4,858 Views)
I can't look at your code, but what you described indicates that you need to learn to use shift registers to hold your current state.
Message 2 of 8
(4,819 Views)
I wonder why you cant see the code. Anyway the way I have it set up I cant use shift registers because the controls are not the same for each state. Or maybe there is but I am not seeing it. I'll reattach the code maybe it will work this time.
Message 3 of 8
(4,795 Views)
The reason what that I was on my phone at the time.
Now that I reread everything here 5 times, I'm pretty sure what you really need to do is implement a State Machine.
Message 4 of 8
(4,782 Views)
I can seen your code, I guess now I can't unsee it...
There is no loop? Don't tell me you run this by using the Continuous Run button!
Here is a couple resources to get you started
https://learn.ni.com/learn/article/labview-tutorial
http://www.ni.com/getting-started/labview-basics/dataflow
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:labview:basics
=== Engineer Ambiguously ===
Message 5 of 8
(4,772 Views)
No I am not using the continuous run button. I know the basics of Labview.
Message 6 of 8
(4,769 Views)
Sorry, when I see such heavy use of flat sequences my first instinct is to direct people to review LabVIEW basics .
Message 7 of 8
(4,765 Views)
Problem is I have tried to do this with a state machine and I am unable to get it to work like how I have it with the sequences. Trust me I don't want to use the sequences just cant seem to get the case structures and event structures to do what I want.
Message 8 of 8
(4,761 Views)
