Help with SSH connection to a Raspberry Pi using LIBSSH2
Hi! I need help 🙂
I´m working on a slow control system for reading the power supply of some Silicon Photomultipliers through a SSH protocol from a Raspberry Pi, using LIBSSH2 toolkit.
I´m getting two main errors, up to this point.
  • Error 5300: SSH write timeout. That I get when after the program gets stuck in the write all.vi
  • Error -8100: [Execute Again Error] The operation has been marked for non-blocking I/O but
    the call would block.
    • This error gets solve when I increase the value of the timeout, but after one interation in the loop it re-apears. If I stop the program and without waiting for a moment I run it agian it also apears. But if I wait a minute before running it again the error is gone, util the first iteration.
If anyone has any ideas on how to solve it I would really appriciate it ❤️
  • 1122334455
(100 Views)
What version of LabVIEW are you using? SSH only works on newer versions of LabVIEW.
Tim
GHSP
(62 Views)
Hi Tim, thx for answering!
LabVIEW 25, so it should not be a problem.
(21 Views)
