Help with Multi point chart plot hile using the waveform data type..
Currently I have two channels being transfered into the AI C-Scan block (by means of a build array) in hopes to display the outputs on a chart as well as an output file. As an outout I am using the waveform data type, as I hear this is the way to go. Problem is that I have the the Waveform chart directly connected to the waveform out put the the AI C-SCAN block but nothing is being displayed on the chart. Although the time is updated on the chart it is listed as the year 1903. I do have data these channels as the there are digital outputs for these channels. Perhaps I should use the AI CONFIG and AI READ clocks rather than this AI C-SCAN. Any ideas...
(2,868 Views)
Christian,
Please see the Real-Time Chart shipping example for LabVIEW. This example describes how to set the base time of the chart so that the time and date are correct.
You may want to autoscale the Y-axis as your data may be out of range of your chart and that is why nothing is seen.
Randy Hoskin
http://www.ni.com/ask
(2,868 Views)
