ASCII to decimal
i would like to ask,
how to change ASCII data into the decimal number by using LABVIEW?
as i receive the data from the external device , using the serial read
and they are strange code.
(I have set the baud rate compatible.)
thanks if you can help me!
(3,805 Views)
Is this more of the problem you were having with your back reflectance meter (RM3750, if I recall)? If the meter is set to the correct baud rate, etc, and you aren't seeing an ASCII string coming back that looks like a readable number, it might be that your meter is set to return the readings as binary values--not ASCII. Can you post a string that you are getting back along with what you think the data value is that it should be reading? This might help troubleshoot the problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,805 Views)
oh...so surprise you can remember me~
yes.....and very happy that, i can get the data in the correct format~
As the timing of the loop is not correct b4(i dont know why
infact..just by trial and error, i set a particular time of the loop
and i get waht i want)
thanks very much ~~
(3,805 Views)
Have you figured out your problem? If not, post an example of the data you are getting back from your box along with a guess as to what should be in the data and I'll see if I can help you sort it out...
Mike...
LabVIEW Champion
(3,805 Views)
yes....i solved that now, thanks for yr kindly help~~
i am still working on the progamme and it's still a long way to reach what i want.
really a hardwork!!haha..but i will still trying hard to do that..
anyway....
thanks very much!!!
(3,805 Views)
feel free to contact me anytime...
Mike Porter
mlportersr@webtv.net
LabVIEW Champion
(3,805 Views)
