Help with Modbus and a CAL 3300 Temperature controller needed!!
Hey! Just wondering how that worked out for you?
Message 41 of 63
(2,169 Views)
I tried to create something simple from the code you sent. It still looks like the code I wrote to start with. Was wondering if you have a RS 232 board included with your CAL 3300 or an RS 485. I have a RS 485 in mine so the wiring connections may need to be changed.
Message 42 of 63
(2,154 Views)
It is now working. I will follow up with a post tomorrow.
Message 43 of 63
(2,140 Views)
I downloaded the Modbus Library and was able to get the program working. I then went back and checked the Modbus functions in LabVIEW 2014 once I knew what I was doing and they worked also. The program had four errors that were solved by a couple of people. Three errors were solved by smithd. The default settings of the CAL 3300 is address 0, baud 9600, parity none, and 1 stop bit. Smithd pointed out that 0 cannot work as a calling ID and the CAL 3300 doesn’t follow Modbus specifications with parity of none. I needed to change the ID to 1 and use even parity. He was also correct that I needed to set a property node to RS485/wire2-Auto. Sundown thankfully provided his code which allowed me to see how to write a new set point to the CAL 3300. The last error was with my wiring. I kept searching for cabling configurations because I thought there had to be an error there since nothing was working with all the help I was getting. I then came across this article
http://www.windmill.co.uk/rs485.html
Which made since to me. That prompted a search under the instrument control forum that resulted in the follow discussion solved by Frabto.
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/RS485-half-duplex-2-wire/td-p/1668918
My new wiring is:
TX/RX+   To pin 4 and 8
TX/RX-    To pin 5 and 9
Gnd         To pin 1
Thanks to all for the help. Sundown can you mark this topic as solved.
Message 44 of 63
(2,123 Views)
I am a beginner using Modbus and if I could see these VI's it would be very helpfull, but i am using an older version of labview, could you please post the screenshot of these VI's ?
Message 45 of 63
(2,034 Views)
Did you look at the two png files from the previous post?
Message 46 of 63
(2,022 Views)
Oh yes sorry I didn't see it was png files, it will help me i will try again tomorrow.
Message 47 of 63
(2,000 Views)
I've made a post here ( but  in french ), if you can have a look please it would help me : http://forums.ni.com/t5/LabVIEW/LV-Modbus-library-1-2-1-Error-code-6101-timeout/td-p/3153674/highlig...
Message 48 of 63
(1,968 Views)
Hey Franco,
Read my post about the solution. Attached are png files on the read function. This is easier to accomplish. Next reply will have the write function.
Message 49 of 63
(1,953 Views)
Write function.
Message 50 of 63
(1,951 Views)
