Help with FileSystemWatcher in .NET
Since I haven't been too familiar with .NET in any language, I'd figure I'd start out with something simple like the FileSystemWatcher. I was wondering if anyone had any experience with the this constructor. How do I make .NET trigger when a file has changed?
I went by the example on the MSDN site for this, but I've hit a snag. Can anyone help? I've included the VI below.
(6,404 Views)
Accepted by topic author Eric1977
Hi Eric,
why don't you study the ready-to-use example in the LabVIEW community?
(6,395 Views)
I wrote a version of soemthing like this once.
The thing to keep in mind is that different applications read and write to files in different ways.
I found Notepad generated multiple events for a single save. Not very friendly 😞
Another FileSystemWatcher example can be found here:
http://blog.jki.net/labs/dont-throw-away-your-throw-away-code/
(6,371 Views)
@GerdW wrote:
Hi Eric,
I didn't see that on my Google search. Probably just skimmed right over it. Thanks.
(6,344 Views)
Callbacks are never simple! 😁 LabVIEW tries to hide away some of the complications but only manages in a limited way to do that. It's definitely not straightforward programming and in a way goes completely against LabVIEW dataflow programming, which is why they chose to implement it as an event in .Net. Unfortunately .Net events don't map easily to LabVIEW events.
Whenever I had to deal with events in .Net or Java code in the past I always had to pinch myself a few times to get my mind wrapped around the correct syntax and not make a total mess of the implementation.
Rolf Kalbermatter  My Blog
(4,091 Views)
