Help with Delete Array
I have a simple question. I have a 2D array, and I use the delete array to get a 1D array. First column only.
22274iABC9BDE856F7077D
I expect the deleted portion to be a 1D array, and not two, even though it correctly puts zeros to the other column.
because the problem is I need to use 1D array as input to other functions, but the delete array output is giving a 2D array out.
(3,094 Views)
Accepted by ade77
Use Index Array to get the column.  The output will be a 1D array.
22276i6B6ACF45E842FD93
- tbob
Inventor of the WORM Global
(3,090 Views)
Read the detailed help for the Delete From Array function.  If you wire the length input you get a 2D array.  If you do not wire the length input the deleted portion has one dimension less.
Unless you really need to delete something, tbob's approach is probably better.
Lynn
(3,072 Views)
