Help wanted to convert NI example 6.1 to 6.0
After getting excellent and fast answers in this group, I'm "almost
there".
A problem I have been deeling with for quite a while is solved in a NI
example...
BUT, the vi is to be downloaded in 6.1 code (that can't be opened using
6.0i...)
I still only have 6.0i, and won't be able to find upgrade for weeks 😞
QUESTION:
Could someone be so very kind to help me converting the example from NI to
version 6.0 by downloading and opening it using LW 6.1, and then use "save
as" with options to save in 6.0 format, and then mail the file to myself
(or make it available for ftp/download...) nnc@fy.chalmers.se
Here is the answer I got, and the link to National Instrument to find the
6.1 vi.
On Fri, 19 Jul 2002, Mache wrote:
> Goran,
> A file is attched with the answer. Just look for "Time Chart Recorder
> Example" Click this and Download it. You will have the Example.
> The Link for this thread is..
> http://exchange.ni.com/servlet/ ProcessRequest?RHIVEID=101&RPAGEID=137&HOID=50650000000500000026890000& HTHREAD=000035110&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Many thanks in advance if anyone has the time to help!
/Göran
(2,542 Views)
Göran,
I've attached what I believe to be the vi you're looking for, converted to ver 6.0i. Good luck!
(2,542 Views)
Many thanks for helping.
It looks to work fine!
(As linked from: http://exchange.ni.com/servlet/com.quiq.servlet.GetObject/Time_Tab.vi?KEY=101.97.103223.14&SIG=101.97.103223.14&EXT=vi
/Göran
(2,542 Views)
