Showing results forĀ
Search instead forĀ
Did you mean:Ā
Help to implement algorithm
Hi everybody, I would ask you some about how to implement on a Labview VI an algorithm developed on MATLAB.
This algorithm is about a optimization problem: I want to find the optimum value of  F (given and known the arrays of values c and b) which reduces (c - F*b).^2. It is a sort of least square method problem.
Also F_ref is set and known. Trapz is the numerical trapezoidal integration function.
% My optimization problem
output = @(F)(c - F*b).^2;
% Solve the optimization problem
for i = (1:1:N)
    % Get old output
    if (i > 1)
        output_old = output_new(i-1);
    else
        output_old = trapz(output(0));
    end;
    % Get new output
    output_new(i) = trapz(output(i*F_ref));
    % Find minimum
    if (output_new(i) > output_old)
        % Select optimal F value
        F_opt = (i-1)*F_ref
        % Break the loop
        break;
    end;
end;
Thank you all in advance
Message 1 of 9
(5,026 Views)
Accepted by topic author EdmondDantes
Hi Edmond,
for i = (1:1:N)
  % Break the loop
  break;
end;
This is a simple FOR loop in LabVIEW, with conditional stop enabled.
if (i > 1)
    else
    end;
IF-THEN-ELSE is a CASE structure in LabVIEW.
When you need values from previous iterations you should use a shift register.
        F_opt = (i-1)*F_ref
Again a CASE structure with some simple math.
Message 2 of 9
(5,014 Views)
I tried to develop the VI and I ran it. Here I attach my VI.
It works (the results are not exactly the ones expected), but, as I am quite new on LabVIEW, I think  it can be debugged and improved because of some errors that I cannot find. Unfortunately I cannot provide the data/signals I used to run the VI.
I attach again the algorithm developed in MATLAB.
for i = (1:1:N)
    % Get old output
    if (i > 1)
    else
    end;
    % Get new output
    % Find minimum
        F_opt = (i-1)*F_ref
        % Break the loop
        break;
    end;
end;
Message 3 of 9
(4,934 Views)
Hi Edmond,
can you please convert the VI to LV2017 (edit->save for previous)?
Which errors do you encountered?
Message 4 of 9
(4,917 Views)
Here  there is 2017 version. Thanks
Message 5 of 9
(4,915 Views)
Hi Edmond,
there's no shift register to access values from previous iteration.
There also is no stop condition in the loop…
Why do you operate on waveforms? Why don't you read the sample array (aka "Y") from the waveforms before the loop?
Why do you multiply the complete waveform by "i * 1e-7"?
I'm sure it can be simplified much more:
Message 6 of 9
(4,910 Views)
Thank you very much for the explanation and your help. Now the vi has more sense.
 But I don't understand how you solved the first "case structure", this one:
for i = (1:1:N)
    % Get old output
    if (i > 1)
    else
    end;
And why did you put the final number indicator as a result of the false case?
Thanks in advance!
Message 7 of 9
(4,896 Views)
Hi Edmond,
I just simplified the code you created by using the MinMax function…
Because you did it in your VI: I didn't change the placing of that terminal…
Message 8 of 9
(4,886 Views)
Hi Edmond,
as I see the same inefficient or "hard to read" code in your new thread I will provide some more snippets:
Message 9 of 9
(4,849 Views)
